Проблема с запуском цикла
Модератор:immortal
- sergejey
- Site Admin
Видимо следует ещё и strict-ошибки отключить.
т.е. итоговая строчка по идее должна быть такой:
E_ERROR | E_WARNING | E_PARSE
Re: Проблема с запуском цикла
Теперь вывод такой:
new minute
ClockChime->onNewMinute
14:31:00 running cycle_scheduler.php
14:31:00 running cycle_execs.php
14:31:00 running cycle_states.php
14:31:00 running cycle_ping.php
14:31:00 running cycle_webvars.php
Checking webvar: http://pogoda.by/pda/?city=26850
14:31:00 running cycle_watchfolders.php
14:31:00 running cycle_rss.php
14:31:01 running cycle_main.php
14:31:01 running cycle_scheduler.php
14:31:01 running cycle_execs.php
14:31:01 running cycle_states.php
14:31:01 running cycle_ping.php
14:31:01 running cycle_webvars.php
14:31:01 running cycle_watchfolders.php
14:31:01 running cycle_rss.php
14:31:02 running cycle_main.php
14:31:02 running cycle_scheduler.php
14:31:02 running cycle_execs.php
14:31:02 running cycle_ping.php
14:31:02 running cycle_states.php
14:31:02 running cycle_webvars.php
14:31:02 running cycle_watchfolders.php
14:31:02 running cycle_rss.php
14:31:03 running cycle_main.php
14:31:03 running cycle_scheduler.php
14:31:03 running cycle_execs.php
14:31:03 running cycle_ping.php
14:31:03 running cycle_states.php
14:31:03 running cycle_webvars.php
14:31:03 running cycle_watchfolders.php
14:31:03 running cycle_rss.php
14:31:04 running cycle_main.php
14:31:04 running cycle_scheduler.php
14:31:04 running cycle_execs.php
14:31:04 running cycle_ping.php
14:31:04 running cycle_states.php
14:31:04 running cycle_webvars.php
14:31:04 running cycle_watchfolders.php
14:31:04 running cycle_rss.php
14:31:05 running cycle_main.php
14:31:05 running cycle_scheduler.php
14:31:05 running cycle_execs.php
14:31:05 running cycle_ping.php
Checking tut.by
14:31:05 running cycle_states.php
14:31:05 running cycle_webvars.php
14:31:05 running cycle_watchfolders.php
14:31:05 running cycle_rss.php
14:31:06 running cycle_main.php
14:31:06 running cycle_scheduler.php
14:31:06 running cycle_execs.php
14:31:06 running cycle_ping.php
14:31:06 running cycle_states.php
14:31:06 running cycle_webvars.php
14:31:06 running cycle_watchfolders.php
14:31:06 running cycle_rss.php
14:31:07 running cycle_main.php
14:31:07 running cycle_scheduler.php
14:31:07 running cycle_execs.php
14:31:07 running cycle_ping.php
14:31:07 running cycle_states.php
14:31:07 running cycle_webvars.php
14:31:07 running cycle_watchfolders.php
14:31:07 running cycle_rss.php
14:31:08 running cycle_main.php
14:31:08 running cycle_scheduler.php
14:31:08 running cycle_execs.php
14:31:08 running cycle_ping.php
14:31:08 running cycle_states.php
14:31:08 running cycle_webvars.php
14:31:08 running cycle_watchfolders.php
14:31:08 running cycle_rss.php
14:31:09 running cycle_main.php
14:31:09 running cycle_scheduler.php
14:31:09 running cycle_execs.php
14:31:09 running cycle_ping.php
14:31:09 running cycle_states.php
14:31:09 running cycle_webvars.php
14:31:09 running cycle_watchfolders.php
14:31:09 running cycle_rss.php
14:31:10 running cycle_main.php
14:31:10 running cycle_scheduler.php
14:31:10 running cycle_execs.php
14:31:10 running cycle_ping.php
14:31:10 running cycle_states.php
14:31:10 running cycle_webvars.php
14:31:10 running cycle_watchfolders.php
14:31:10 running cycle_rss.php
14:31:11 running cycle_main.php
14:31:11 running cycle_scheduler.php
14:31:11 running cycle_execs.php
14:31:11 running cycle_ping.php
14:31:11 running cycle_states.php
14:31:11 running cycle_webvars.php
14:31:11 running cycle_watchfolders.php
14:31:11 running cycle_rss.php
14:31:12 running cycle_main.php
14:31:12 running cycle_scheduler.php
14:31:12 running cycle_execs.php
14:31:12 running cycle_ping.php
14:31:12 running cycle_webvars.php
14:31:12 running cycle_watchfolders.php
14:31:12 running cycle_rss.php
14:31:12 running cycle_states.php
14:31:13 running cycle_main.php
14:31:13 running cycle_scheduler.php
14:31:13 running cycle_execs.php
14:31:13 running cycle_ping.php
14:31:13 running cycle_webvars.php
14:31:13 running cycle_watchfolders.php
14:31:13 running cycle_rss.php
14:31:13 running cycle_states.php
14:31:14 running cycle_main.php
14:31:14 running cycle_scheduler.php
14:31:14 running cycle_execs.php
14:31:14 running cycle_ping.php
14:31:14 running cycle_webvars.php
14:31:14 running cycle_watchfolders.php
14:31:14 running cycle_rss.php
14:31:14 running cycle_states.php
14:31:15 running cycle_main.php
14:31:15 running cycle_scheduler.php
14:31:15 running cycle_execs.php
14:31:15 running cycle_ping.php
14:31:15 running cycle_webvars.php
14:31:15 running cycle_watchfolders.php
14:31:15 running cycle_rss.php
14:31:16 running cycle_states.php
14:31:16 running cycle_main.php
14:31:16 running cycle_scheduler.php
14:31:16 running cycle_execs.php
14:31:16 running cycle_ping.php
Checking tut.by
14:31:16 running cycle_webvars.php
14:31:16 running cycle_watchfolders.php
14:31:16 running cycle_rss.php
14:31:17 running cycle_states.php
14:31:17 running cycle_main.php
14:31:17 running cycle_scheduler.php
14:31:17 running cycle_execs.php
Так и должно быть? и наверное его в автозагрузку прописать надо? если надо то подскажите как лучше.
И еще если закрываю окно консоли, при подключении через SSL то почему-то цикл прекращает свое действие.
new minute
Checking tut.by
Checking tut.by
С переходом системы на другую машину, начались остановки цикла, куда копать, как правило останавливается на строчке cycle main.php, cscript.exe в процессах не наблюдается.
Выяснил, что остановки происходят при подключенном mqtt протоколе, как найти причину?
- sergejey
- Site Admin
по идее скрипт mqtt_daemon.php, работающий с этим протоколом, на основной цикл влиять не должен, если он запускается отдельно. теоретически, дело может быть в обновлении свойства объекта, связанного с mqtt-устройством -- в таком случае процедура обновления может зависнуть, если запись не в mqtt-устройство не удалась, но там тоже стоит тайм-аут да и сама процедура обновления с основным циклом не особо связана. пока мистика.Urbas81 писал(а):Выяснил, что остановки происходят при подключенном mqtt протоколе, как найти причину?
а если нажать Ctrl+C и потом на вопрос об остановке выполнения bat-файла выбрать Нет, то цикл перезапустится нормально или уже не поднимается?
Попробую, отпишусь.sergejey писал(а):по идее скрипт mqtt_daemon.php, работающий с этим протоколом, на основной цикл влиять не должен, если он запускается отдельно. теоретически, дело может быть в обновлении свойства объекта, связанного с mqtt-устройством -- в таком случае процедура обновления может зависнуть, если запись не в mqtt-устройство не удалась, но там тоже стоит тайм-аут да и сама процедура обновления с основным циклом не особо связана. пока мистика.Urbas81 писал(а):Выяснил, что остановки происходят при подключенном mqtt протоколе, как найти причину?
Значит попробовал с Ctrl+C, окно Majordomo закрылось не спросив ничего, окно mqtt спросило, после выбора нет, тоже закрылось.
Помогите разобраться с
ну и на веб морде
PHP Strict Standards: Declaration of objects::saveParams() should be compatible with module::saveParams($data = 1) in /var/www/html/modules/objects/objects.class.php on line 609
PHP Strict Standards: Declaration of objects::install() should be compatible with module::install($parent_name = '') in /var/www/html/modules/objects/objects.class.php on line 609
PHP Strict Standards: Declaration of objects::dbInstall() should be compatible with module::dbInstall($data) in /var/www/html/modules/objects/objects.class.php on line 609
PHP Fatal error: Call to undefined function curl_init() in /var/www/html/modules/objects/objects.class.php on line 279
main cycle stopped.. exec cycle stopped.. scheduler cycle stopped.. ping cycle stopped.. webvars cycle stopped.. watch folders cycle stopped.. RSS cycle stopped.
Надо доустановить curl.PHP Fatal error: Call to undefined function curl_init()
sudo apt-get install curl libcurl3 libcurl3-dev php5-curl
sergejey писал(а):Urbas81 писал(а): а если нажать Ctrl+C и потом на вопрос об остановке выполнения bat-файла выбрать Нет, то цикл перезапустится нормально или уже не поднимается?
Продолжает зависать цикл, вчера пару раз после нажатия CTRL-C, система начинала перезапуск без закрытия окна.
