а версия пхп какая?
Error logs в Apache
Re: Error logs в Apache
У меня такие же ошибки прут. Подскажите каким методом искать методы ?
[Fri Feb 14 07:24:39.691690 2020] [php7:warn] [pid 19255] [client 127.0.0.1:53044] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
[Fri Feb 14 07:24:52.316081 2020] [php7:warn] [pid 16454] [client 127.0.0.1:53914] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
[Fri Feb 14 07:25:47.823751 2020] [php7:warn] [pid 16477] [client 127.0.0.1:58342] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
[Fri Feb 14 07:26:57.891805 2020] [php7:warn] [pid 21427] [client 127.0.0.1:35290] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
[Fri Feb 14 07:27:06.027172 2020] [php7:warn] [pid 21427] [client 127.0.0.1:35924] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
[Fri Feb 14 07:28:06.757238 2020] [php7:warn] [pid 20830] [client 127.0.0.1:40244] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
[Fri Feb 14 07:28:57.197335 2020] [php7:warn] [pid 23241] [client 127.0.0.1:44026] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
[Fri Feb 14 07:29:09.337671 2020] [php7:warn] [pid 23315] [client 127.0.0.1:44890] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
Я не спец), искал так:dmsergei писал(а): ↑Пт фев 14, 2020 9:30 pmУ меня такие же ошибки прут. Подскажите каким методом искать методы ?СпойлерПоказать[Fri Feb 14 07:24:39.691690 2020] [php7:warn] [pid 19255] [client 127.0.0.1:53044] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
1)Посмотрел на время ошибки и строку ошибки
2) в X-RAY во вкладке метод нашел по времени что исполнялось
3) Нашел этот скрипт или метод по названия и в указанной строке проверял вычисления и переменные.
де жа вю, вроде б был ответ здесь про титлеdmsergei писал(а): ↑Пт фев 14, 2020 9:30 pmУ меня такие же ошибки прут. Подскажите каким методом искать методы ?СпойлерПоказать[Fri Feb 14 07:24:39.691690 2020] [php7:warn] [pid 19255] [client 127.0.0.1:53044] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
в 10 строке надо в условии поправить
Вот копаю форум не вижу. Где и как надо что поправить.Logrus писал(а): ↑Вс фев 16, 2020 6:20 pmде жа вю, вроде б был ответ здесь про титлеdmsergei писал(а): ↑Пт фев 14, 2020 9:30 pmУ меня такие же ошибки прут. Подскажите каким методом искать методы ?СпойлерПоказать[Fri Feb 14 07:24:39.691690 2020] [php7:warn] [pid 19255] [client 127.0.0.1:53044] PHP Warning: A non-numeric value encountered in /var/www/modules/objects/objects.class.php(598) : eval()'d code on line 10
был утром пост здесь или мне померещилось
там вам и предлагали показать что, где и как у вас, в локациях, в румс в свойстве Титле и тп.
попробуйте в альфе крайняя правка - возможно поможет
Ну хоть убейте не могу найти .
Такая проблема видно не только у меня но почемуто решения так и нет.
внимательно и полностью еще раз перечитайте пост выше
