[Thu Jan 23 20:41:56.439446 2020] [core:warn] [pid 9736:tid 656] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 23 20:41:56.470686 2020] [ssl:warn] [pid 9736:tid 656] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jan 23 20:41:57.173800 2020] [mpm_winnt:notice] [pid 9736:tid 656] AH00455: Apache/2.4.41 (Win64) OpenSSL/1.1.1c PHP/7.3.12 configured -- resuming normal operations
[Thu Jan 23 20:41:57.173800 2020] [mpm_winnt:notice] [pid 9736:tid 656] AH00456: Apache Lounge VC15 Server built: Aug 11 2019 12:20:04
[Thu Jan 23 20:41:57.173800 2020] [core:notice] [pid 9736:tid 656] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Thu Jan 23 20:41:57.173800 2020] [mpm_winnt:notice] [pid 9736:tid 656] AH00418: Parent: Created child process 10168
[Thu Jan 23 20:41:58.564604 2020] [ssl:warn] [pid 10168:tid 636] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jan 23 20:41:58.642615 2020] [ssl:warn] [pid 10168:tid 636] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jan 23 20:41:58.720713 2020] [mpm_winnt:notice] [pid 10168:tid 636] AH00354: Child: Starting 150 worker threads.
"df" Ґ пў«пҐвбп ўгв॥© Ё«Ё ўҐиҐ©
Є®¬ ¤®©, ЁбЇ®«пҐ¬®© Їа®Ја ¬¬®© Ё«Ё Ї ЄҐвл¬ д ©«®¬.
"cat" Ґ пў«пҐвбп ўгв॥© Ё«Ё ўҐиҐ©
sethostname: ў®бЇ®«м§г©вҐбм Ї Ґ«мо гЇа ў«ҐЁп ¤«п § ¤ Ёп Ё¬ҐЁ г§« .
hostname -s Ґ Ї®¤¤Ґа¦Ёў Ґвбп.
[Thu Jan 23 21:41:59.405362 2020] [php7:warn] [pid 10168:tid 1896] [client 127.0.0.1:65211] PHP Warning: A non-numeric value encountered in C:\\xampp\\htdocs\\modules\\objects\\objects.class.php(619) : eval()'d code on line 10
$success = eval($code);
if ($success === false) {
//getLogger($this)->error(sprintf('Error in "%s.%s" method.', $this->object_title, $name));
registerError('method', sprintf('Exception in "%s.%s" method.', $this->object_title, $name));
стоит обращать внимание на это :
[Thu Jan 23 20:41:58.642615 2020] [ssl:warn] [pid 10168:tid 636] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name?
