Умер mysql после обновление MJ
Добавлено: Пн дек 31, 2018 11:40 am
Всем привет, не запускается MJ после обновления, при входе на страницу выходит сообщение Can't connect to database (2002: No such file or directory) не может подключится к базе, система установлена на OrenagePiPc при попытке запустить mysql в ручную выходит:
● mysql.service - MySQL Community Server
Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
Active: activating (start-post) (Result: exit-code) since Mon 2018-12-31 16:35:51 +08; 6s ago
Process: 8295 ExecStart=/usr/sbin/mysqld (code=exited, status=2)
Process: 8284 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Main PID: 8295 (code=exited, status=2); : 8296 (mysql-systemd-s)
CGroup: /system.slice/mysql.service
└─control
├─8296 /bin/bash /usr/share/mysql/mysql-systemd-start post
└─8393 sleep 1
Dec 31 16:35:51 orangepipc systemd[1]: Starting MySQL Community Server...
Dec 31 16:35:53 orangepipc systemd[1]: mysql.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
В логах:
InnoDB: http://dev.mysql.com/doc/refman/5.7/en/ ... overy.html
InnoDB: about forcing recovery.
08:37:28 UTC - mysqld got signal 6 ;
This could be because you hit a bug. It is also possible that this binary
or one of the libraries it was linked against is corrupt, improperly built,
or misconfigured. This error can also be caused by malfunctioning hardware.
Attempting to collect some information that could help diagnose the problem.
As this is a crash and something is definitely wrong, the information
collection process might fail.
key_buffer_size=16777216
read_buffer_size=131072
max_used_connections=0
max_threads=151
thread_count=0
connection_count=0
It is possible that mysqld could use up to
key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 75744 K bytes of memory
Hope that's ok; if not, decrease some variables in the equation.
Thread pointer: 0x9e600490
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong...
stack_bottom = 9cdfecc0 thread_stack 0x30000
Trying to get some variables.
Some pointers may be invalid and cause the dump to abort.
Query (0): Connection ID (thread ID): 0
Status: NOT_KILLED
The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains
information that should help you find out what is causing the crash.
Уже было такое, но решения я так и не нашел, в итоге пришлось всё сносить и начинать сначала
└─control
└─8393 sleep 1
В логах:
max_threads=151
thread_count=0
connection_count=0
terribly wrong...
Status: NOT_KILLED
