Re: SLS ZigBee Gateway
Добавлено: Пт фев 14, 2020 6:57 pm
Поддержка бле есть?
Только в планах, на сколько я знаю =)
Шлюз не видит Livolo Wall switch? Что в логах , я не понимаю(
[15:23:31.594] [MQTT] Send HB (202) {"Uptime":12728,"UptimeStr":"03:32:08","IP":"192.168.0.132","RSSI":"-61","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":60,"LastTxTS":60,"log_level":"debug","permit_join":false}
[15:22:31.594] [MQTT] Send HB (200) {"Uptime":12668,"UptimeStr":"03:31:08","IP":"192.168.0.132","RSSI":"-51","Version":"2020.02.07d1","FreeMem":110340,"memoryUsage":1008,"LastRxTS":0,"LastTxTS":0,"log_level":"debug","permit_join":false}
[15:22:31.591] Joining disable
[15:22:31.590] [D] -- ReceiveCmd: 0x45B6 AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, Len: 3, Data: 000000
[15:22:31.589] [D] WaitingForMessage Cmd: 0x45B6 AREQ_ZDO_MGMT_PERMIT_JOIN_RSP
[15:22:31.587] [D] -- ReceiveCmd: 0x6536 SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, Len: 1, Data: 00
[15:22:31.574] [D] WaitingForMessage Cmd: 0x6536 SRSP_ZDO_MGMT_PERMIT_JOIN_REQ
[15:22:31.573] [D] -- SendCmd 0x2536 SREQ_ZDO_MGMT_PERMIT_JOIN_REQ, DataLen: 5, Data: 0FFCFF0000
[15:22:31.571] [D] WebZigBeeJoin Duration: 0
[15:22:23.907] [MQTT] Send HB (201) {"Uptime":12660,"UptimeStr":"03:31:00","IP":"192.168.0.132","RSSI":"-59","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":60,"LastTxTS":60,"log_level":"debug","permit_join":true}
[15:21:39.321] SaveDevices()
[15:21:23.907] [MQTT] Send HB (199) {"Uptime":12600,"UptimeStr":"03:30:00","IP":"192.168.0.132","RSSI":"-58","Version":"2020.02.07d1","FreeMem":113568,"memoryUsage":1008,"LastRxTS":0,"LastTxTS":0,"log_level":"debug","permit_join":true}
[15:21:23.904] Joining enable
[15:21:23.903] [D] -- ReceiveCmd: 0x45B6 AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, Len: 3, Data: 000000
[15:21:23.902] [D] WaitingForMessage Cmd: 0x45B6 AREQ_ZDO_MGMT_PERMIT_JOIN_RSP
[15:21:23.900] [D] -- ReceiveCmd: 0x6536 SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, Len: 1, Data: 00
[15:21:23.888] [D] WaitingForMessage Cmd: 0x6536 SRSP_ZDO_MGMT_PERMIT_JOIN_REQ
[15:21:23.887] [D] -- SendCmd 0x2536 SREQ_ZDO_MGMT_PERMIT_JOIN_REQ, DataLen: 5, Data: 0FFCFFFF00
[15:20:48.381] [MQTT] Send HB (204) {"Uptime":12566,"UptimeStr":"03:29:26","IP":"192.168.0.132","RSSI":"-57","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":600,"LastTxTS":600,"log_level":"debug","permit_join":false}
[15:19:48.380] [MQTT] Send HB (204) {"Uptime":12506,"UptimeStr":"03:28:26","IP":"192.168.0.132","RSSI":"-59","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":540,"LastTxTS":540,"log_level":"debug","permit_join":false}
[15:18:48.379] [MQTT] Send HB (204) {"Uptime":12446,"UptimeStr":"03:27:26","IP":"192.168.0.132","RSSI":"-59","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":480,"LastTxTS":480,"log_level":"debug","permit_join":false}
[15:17:48.378] [MQTT] Send HB (204)
Ливоло вроде не умеет быть роутером. Если и умеет, я не рекомендовал надеяться на корректную маршрутизацию через них, так как прошивки для ливоло писали индусские школьники.Nail писал(а): ↑Пт фев 28, 2020 2:45 pmШлюз не видит Livolo Wall switch? Что в логах , я не понимаю(Хотя на нем висит мотор Агара но антенна ели ели, может не достает до выключателя через стены(4 метра)?Код: Выделить всё
[15:23:31.594] [MQTT] Send HB (202) {"Uptime":12728,"UptimeStr":"03:32:08","IP":"192.168.0.132","RSSI":"-61","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":60,"LastTxTS":60,"log_level":"debug","permit_join":false} [15:22:31.594] [MQTT] Send HB (200) {"Uptime":12668,"UptimeStr":"03:31:08","IP":"192.168.0.132","RSSI":"-51","Version":"2020.02.07d1","FreeMem":110340,"memoryUsage":1008,"LastRxTS":0,"LastTxTS":0,"log_level":"debug","permit_join":false} [15:22:31.591] Joining disable [15:22:31.590] [D] -- ReceiveCmd: 0x45B6 AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, Len: 3, Data: 000000 [15:22:31.589] [D] WaitingForMessage Cmd: 0x45B6 AREQ_ZDO_MGMT_PERMIT_JOIN_RSP [15:22:31.587] [D] -- ReceiveCmd: 0x6536 SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, Len: 1, Data: 00 [15:22:31.574] [D] WaitingForMessage Cmd: 0x6536 SRSP_ZDO_MGMT_PERMIT_JOIN_REQ [15:22:31.573] [D] -- SendCmd 0x2536 SREQ_ZDO_MGMT_PERMIT_JOIN_REQ, DataLen: 5, Data: 0FFCFF0000 [15:22:31.571] [D] WebZigBeeJoin Duration: 0 [15:22:23.907] [MQTT] Send HB (201) {"Uptime":12660,"UptimeStr":"03:31:00","IP":"192.168.0.132","RSSI":"-59","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":60,"LastTxTS":60,"log_level":"debug","permit_join":true} [15:21:39.321] SaveDevices() [15:21:23.907] [MQTT] Send HB (199) {"Uptime":12600,"UptimeStr":"03:30:00","IP":"192.168.0.132","RSSI":"-58","Version":"2020.02.07d1","FreeMem":113568,"memoryUsage":1008,"LastRxTS":0,"LastTxTS":0,"log_level":"debug","permit_join":true} [15:21:23.904] Joining enable [15:21:23.903] [D] -- ReceiveCmd: 0x45B6 AREQ_ZDO_MGMT_PERMIT_JOIN_RSP, Len: 3, Data: 000000 [15:21:23.902] [D] WaitingForMessage Cmd: 0x45B6 AREQ_ZDO_MGMT_PERMIT_JOIN_RSP [15:21:23.900] [D] -- ReceiveCmd: 0x6536 SRSP_ZDO_MGMT_PERMIT_JOIN_REQ, Len: 1, Data: 00 [15:21:23.888] [D] WaitingForMessage Cmd: 0x6536 SRSP_ZDO_MGMT_PERMIT_JOIN_REQ [15:21:23.887] [D] -- SendCmd 0x2536 SREQ_ZDO_MGMT_PERMIT_JOIN_REQ, DataLen: 5, Data: 0FFCFFFF00 [15:20:48.381] [MQTT] Send HB (204) {"Uptime":12566,"UptimeStr":"03:29:26","IP":"192.168.0.132","RSSI":"-57","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":600,"LastTxTS":600,"log_level":"debug","permit_join":false} [15:19:48.380] [MQTT] Send HB (204) {"Uptime":12506,"UptimeStr":"03:28:26","IP":"192.168.0.132","RSSI":"-59","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":540,"LastTxTS":540,"log_level":"debug","permit_join":false} [15:18:48.379] [MQTT] Send HB (204) {"Uptime":12446,"UptimeStr":"03:27:26","IP":"192.168.0.132","RSSI":"-59","Version":"2020.02.07d1","FreeMem":113628,"memoryUsage":1008,"LastRxTS":480,"LastTxTS":480,"log_level":"debug","permit_join":false} [15:17:48.378] [MQTT] Send HB (204)
что то у автора Aven нет свежей ссылки на полное оборудование , а то старая не работает?directman66 писал(а): ↑Пт фев 28, 2020 2:53 pmЛиволо вроде не умеет быть роутером. Если и умеет, я не рекомендовал надеяться на корректную маршрутизацию через них, так как прошивки для ливоло писали индусские школьники.
Список оборудования будет на другом ресурсе. Сейчас в процессе. Пока пользуйтесь список из описания к прошивке.Nail писал(а): ↑Пт фев 28, 2020 3:36 pmчто то у автора Aven нет свежей ссылки на полное оборудование , а то старая не работает?directman66 писал(а): ↑Пт фев 28, 2020 2:53 pmЛиволо вроде не умеет быть роутером. Если и умеет, я не рекомендовал надеяться на корректную маршрутизацию через них, так как прошивки для ливоло писали индусские школьники.
Все правильно, он не шлет false, только true не чаще раз в минуту (если движение продолжается)... если движения нет, то просто ничего не шлет... соответственно привяжите его к стандартному классу sMotions, и поставьте у объекта свойство timeout больше минуты, например 90, тогда после 1,5 минут после последнего зафиксированного движения ваш объект будет иметь 0 в статусе... Так работают все датчики движения что я видел не зависимо от протокола.
