When facing the "The file is too large for the destination file system" issue in Windows 10/8/7, you might get confused about why you would not be able to copy the file to your USB flash drive when there is sufficient free space.
The problem occurs because one of the files you want to transfer is larger than 4 GB and your USB flash drive is using the FAT32 file system, of which the maximum file size is 4GB. For a FAT16 USB flash drive, the maximum file size is 2GB. There is a built-in limitation in the FAT32 file system: Although the total size of the files you can store on a FAT32 drive could be up to 2TB, you cannot save an individual file that exceeds 4GB on it.
Thanks!
What's The Reason for The 'file is too large' Error?
- prmres
Re: What's The Reason for The 'file is too large' Error?
Is it a question?
or a story?
limiting filesystems by file size is an open secret
or a story?
Не только лишь все!
- xor
это бот какой-то или бескорыстный просветитель, судя по его двум постам
