В админке mysql при выборе любой таблице говорит что на сервере есть ошибки:
Warning in ./libraries/sql.lib.php#613
count(): Parameter must be an array or an object that implements Countable
Backtrace
./libraries/sql.lib.php#2128: PMA_isRememberSortingOrder(array)
./libraries/sql.lib.php#2079: PMA_executeQueryAndGetQueryResponse(
array,
boolean true,
string 'db_terminal',
string 'classes',
NULL,
NULL,
NULL,
NULL,
NULL,
NULL,
string '',
string './themes/pmahomme/img/',
NULL,
NULL,
NULL,
string 'SELECT * FROM `classes`',
NULL,
NULL,
./sql.php#221: PMA_executeQueryAndSendQueryResponse(
array,
boolean true,
string 'classes',
NULL,
NULL,
NULL,
NULL,
NULL,
NULL,
string '',
NULL,
NULL,
NULL,
NULL,
NULL,
